BlazerBill
- Mar 24, 2023
- Texas
- Billy
- Chevy K5 Blazer
I try to use less chemically harsh solutions for dissolving heavy rust and old paint through soaking parts like nuts and bolts and I’ve tried darn near every rust neutralizer and acid chemicals on the market that are also harder to dispose and of course have used diesel fuel. Several years ago, I poured 10% common Vinegar into a rusty 1980’s motorcycle gas tank and after about a week, all the rust was gone. Well, I recently saw 80% strength vinegar on Amazon. Lower % strengths are also available. I ordered the 80% to see what it would do so I soaked some very heavily rusted bolts and washers. The washers were solidly rusted onto the bolts. I also soaked some other old heavily painted over bolts. I soaked them all in the vinegar for a whole week and to my amazement the rust was 95% dissolved and the old paint was loosened. With additional very light hand wire brushing all the loose corrosion and paint was removed. Before, soaking them I had even tried powered wire wheel brushing (which is a PITA and can literally be painful) with no significant removal of the heavier rust under the loose surface rust. This 80% vinegar is serious stuff and the smell will knock your socks off and be damn sure to use goggles and heavy rubber gloves. Vinegar is the next best method without having a media blaster or a parts tumbler or solvent tank for smaller parts. The vinegar even removed the rust in the rust pits. See pics attached. I didn’t think it would work to remove this level of rust so I didn’t take before pics but took the after soaking pics and after light hand wire brushing and water rinse to remove the gunk. You could try to spray it onto vertical surfaces like with Fast Etch but of course it won’t stay on very well. Keep in mind the vinegar was clear colored before soaking the rusty parts.
