HELP!!! How do I hook up a CS130 alternator, I upgraded, but now stuck LOL
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
I kept having problems with my factory setup and PS pump because I was missing a bracket and running
headers. Not to mention belt noise:eek:..
I had a 1992 Pontiac Trans Am front accessory serpentine drive laying around and decided to use it.
Everything came out good, but the old alt and new alt are different in plugs.
How do I get this to work CORRECTLY???? Is there a adapter plug? I do not want to Jerry rig this.
I want to fix it correctly. THANKS!!
1985 Silverado K20 350/400
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Don't remember what I did it on but I had a new plug that didn't match the old one's shape. Think it was a 'L' plug to a rectangle plug. Took needle nose plyers and pulled the connectors out on the nonfitting plug and matched up where they went on the old plug and pushed them into the correct fitting plug.
If the prongs are the same size it's free with a couple minutes of work.
sallyjeank10
