Headliner question
td87
CT
Trevor
V20
Although I wouldn't begin this project for a few weeks if its even possible but my 87 came from the factory w/out a headliner, so my question is if anyone ever installed one?
What are you using for a headboard, you buying a new one or getting one from a junkyard?
chengny
Once you have a usable headboard shell in hand, here is how to make it look like it just came from the factory:
1. The molded backing board/shell (don't quote me on nomenclature) is the key to this whole repair. It is just as well that you have to get one because it cannot be in the vehicle to do this properly.
2. Peel the old headliner fabric carefully away from the shell. If any pieces of the shell start to come off with the fabric separate them with a butter knife and set them aside. If you can't locate a perfect shell at the junkyard or don't want to pay for a new one you can glue them back into the original with adhesive cement.
3. Step back and see what you have to work with. If you are lucky the fabric will have cleanly separated from the fiberglass shell. If not that is why you so carefully saved those little chunks.
4.Get a shop-vac and a brand new toilet brush (toilet brush - not a wire brush). Get down on your hands and knees and start firmly but gently (can I say that?) removing all of the failed adhesive. Rather like when your wife gets her face exfoliated. Don't worry if some of the shell carries away - it is actually better to get down to a new surface. After you are done scrubbing use the soft brush attachment for the vacuum and get all that old glue off. Then get your toilet brush back in hand and do it all over again, and again until you have a new surface to work with.
5. Go to the Home Depot and get a couple of cans of spray-on polyurethane and 4 cans of 3M heavy duty adhesive. (Oh yeah and a paint roller with a nice fluffy cartridge)
6. Spray the newly cleaned shell with the poly and let it dry overnight. In the AM you should find that you have a nice hard/firm/sturdy shell to work with.
7. I forgot to tell you that on the way home from Home Depot you should have gone to JoAnn Fabrics and asked one of the nice ladies there to direct you to the headliner material - they'll know exactly what you mean. You also should have measured your shell or brought your old headliner fabric with you in a plastic bag. They at JA Fabrics will set you up a beautiful piece of foam backed headliner that is thick enough to hide any gouges you may have made during the cleaning process.
8. Back down on your hands and knees and lay the new material out over the shell trim away to fit (leaving about two inches over on all sides.
9. You can guess the rest - read the instructions on the 3M can. I believe it will say to spray both surfaces and wait 30 minutes before joining. Use all 4 cans - trust me! It will look like a winter wonderland, but that's correct.
10. Have an assistant help you lay the fabric back down on the shell and get that new paint roller that I forgot to mention earlier. Get back down on your H&K's again and while gently tugging where needed, start rolling the fabric onto the shell.
11. Let it dry, do the final trimming of excess fabric and get ready to hang up in the truck.
One note; depending on the contours of your shell it may be prudent to place some folded up towels under certain areas of the shell so that when you roll the glue into the interface you can press down firmly.
This will work and you will not be able to take your eyes off of the wonderful job you did ( and keep showing people till they are sick of hearing about it). It will last for 20 years.
To hang a headliner in a truck - even one that has never had one is not a big deal.
But a word to the wise; don't even start until you have all the trim/support pieces on hand. Paint and straighten them before assembly.
1. Front and rear & L/R side mouldings
2. L/R front & rear pillar mouldings
3. Hinge/mounting bracket assemblies for the sunvisors.
The holes in the H/L (for the visors and the dome light) will match up even on a non-H/L truck. Use these as locating points. Have a helper hold the H/L up in place and get a couple of screws in the side trim first. After you are pleased with how it fits, do the front and rear trim.
allanchevy86
