Headers??
fish on
Harrington, De
Phil
V20
I have a 1987 V20 with a 350 and i am looking to put long tube headers on it. I was wondering if anyone has insite on the best brand and any other mods that will need to be done to clear the headers.
Thanks
83swb
CT
Hunter
83'
350/th350
If you still have your fuel injection on it you will have to weld in tabs on the headers for O2 sensors (someone correct me if I'm wrong), if your carb'd then scratch that. Hedman, Hooker, and Doug's headers are good quality. Seems you get what you pay for with headers, but theres no need to spend $700 on a pair. As far as other modifications required, you may have to buy new plug wires depending on the style of header, only other thing would be a new exhaust if you still have a single exhaust or if you have duals already you are probably going to need new midpipes or your current exhaust bent to meet the header collectors.
8T6K5
AZ
L98 350 TPI
Some will come with the bungs already there...
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
my carbed k10 did great with flowtechs headers. under 200 shipped, but i have to modify the central bumpstop bracket if i wanna put that back on. otherwise i recommend it
Driver4r
Nebraska
Trevor
k10,c20
Get a set of G-Body headers, they will tuck up under the truck alot better.
hirschdalechevy
norcal
rich
k-30
I only run doug's or doug thorley's on a truck. They are costly but you never have any problems , like the cheap headmans and hookers.
Doug thorley's are my number one , (way thicker material).
8T6K5
AZ
L98 350 TPI
hirschdalechevy
norcal
rich
k-30
sweeeeeeeeeeet ^^^^^^^^^^^^^^^^^^
Great headers
The last set I bought were coated Hedman Elite's, they are much thicker material than the regular Hedmans.
fish on
Harrington, De
Phil
V20
Thx for the info guys! i was wondering what will happen if i pull the smog pump and tubes?
8T6K5
AZ
L98 350 TPI
As far as the headrers go, just plug the bungs with 1/4 brass plugs...as seen in my pic.
For the pump, gut it and let it free-spin - use a delete pulley or toss it and use shorter belt.
fish on
Harrington, De
Phil
V20
where can you get a delete pulley? I am thinking about getting headers with out the air injection plugs and getting rid of the smog system completely
fish on
Harrington, De
Phil
V20
Thx, i appreciate all the help! sorry to burn your ears up with all the questions.
nathanjohnson85
