Headers...plug n play???
fallguy
Minot, ND
Jamie
Silverado K10
'86 350 with AC. What headers are going to be plug and play with no mods and still get to my plugs without a major issue?
87ChevyR10
Kansas
NA
NA
NA
None of the aftermarket headers are true plug'n'play. If you still have the AIR pump installed and working, you'll need to remove all of that in order to use after market headers.
EDIT> If you're gonna take the time to remove the AIR pump system, might as well save some $$$ and get long tube headers. Summit makes a set for half the price of shorty headers http://www.summitracing.com/parts/sum-g9006/overview/year/1987/make/chevrolet/model/r10
EDIT 2: You can get those Summit Long Tube Headers and these (http://www.summitracing.com/parts/big-50230flt/overview/) for $180.00 Then go to AutoZone or a muffler shop and get some tubing which will fit the outlet of the muffler. Prolley spend close if not a tad more than on this setup than buying hte the shorty headers only.
The setup above is what I will get for my truck soon.
nvrenuf
Mobile, Al.
There will also be a trip to the muffler shop to hook up the pipes to the headers.
87ChevyR10
Kansas
NA
NA
NA
Not if he gets the type of mufflers I linked. They bolt directly to the collectors.
I wonder how loud the truck will be with glass packs bolted directly to the headers and dumping under the cab somewhere?
fallguy
Minot, ND
Jamie
Silverado K10
I have no smog control on the truck.
Any performance differences between the long tube and short headers?
87ChevyR10
Kansas
NA
NA
NA
That'll make your life a bit easier then. I imagine long tubes will have the advantage due to having larger diameter tubing for each exhaust port. Could be wrong though. I just know that the shorties are twice the cost of some long tubes.
gpmorgan
Tupelo Ms.
greg
I paid like 100 bucks for my shortys:
gpmorgan
Tupelo Ms.
greg
That was a great buy. What brand are they?
Swims350
Logan WV
none
IF you find shorties with a ball end they might fit with no mods.
these trucks most I saw had one dumped straight down or both, on stock manifolds which made it different from most headers.
Most headers use a flat flange, that will not work as direct bolt on, you'd need the factory pipe ends cut off and reducers clamped or welded on.
bolt on muflers will not fit on some trucks, our 86 k10 had no straight shot from long tubes, and neither did old man's 84 c10 so even if they are flange bolt on mufflers they won't just bolt up.
Charkmapman
