Headers for ls swap with sm465
hoagster
Air Force Supporting Member
California
K10, 1500
5.3l
I just got my pump in today, just an in-line tell I get some tanks and all the parts to go with it, probably not the best place to run my fuel lines but seem the easiest
That actually looks good. I have been researching the fuel distribution stuff. I originally had two tanks, one a aftermarket on the drivers side. Going to install 2 new tanks but haven't decided if I'm going to run a inline or in tank yet.
Nicholson72
Ca
Ls 5.3
Thanks, I had a 87 parts truck that I got the manual out of that’s how I have the hydraulic slave cylinder and I got rid of it and now I wish I still had it I could sure use the tanks out of it now haha I thought about the blazer fuel tank swap but I’m not sure where I would run the filler neck, my bed is way to clean to be cutting a hole in it
RoryH19
Rory
R10 Silverado SWB
Looks good. I recently did a 6.0/4L65e swap into my K5 Blazer.
It came from a 04 Escalade.
Ran my fuel down the left side since that's where the Escalade was originally.
I went with the intake fuel pump and vette style regulator/return. Works well and also keeps the pump cooler than on a frame rail.
If you want to go with Blazer tank you could also put a hole in the bed floor if your bed sides are too nice.
I went with SS shorty headers for my swap. Fits well and clears the trans linkage. They also came with the 02 bungs.
sht2kll
Elko, Nevada
Tom
M1008
Howdy Nicholson, do not mean to high Jack or change the subject of your post, but you might be able to answer my question? I just bought an 87 V20 with an SM465. I am putting an L59 (5.3) in it I wanted to know what flywheel, disc, pressure plate and pilot bushing I might need? Thanks for any help Tom
Nicholson72
Ca
Ls 5.3
So for the flywheel I used the
sachs NFW1050, the stock clutch and stock pressure plate bolts up to it, only thing on the pressure plate was like every other hole you just got to drill the holes out a little bit and as for the pilot bearing I used the ls7 sealed bearing
redrosec10
