headers are here. Is this gonna be a problem? pic inside.
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
After looking at many headers including the stainless ones. I bought some hookers. They were real junk I had to send them back. warped flanges.
I ended up with HEDMAN headers. 1 5/8 with 3 in collector.
These were built very well. Only problem is(and I think I may send them back)
when they were ground flat at the flanges, only one tube is ground to much. I dont want future problems with leaking gaskets. I know how they square the flanges and it looks like only one got grounded down almost flat but at an angle. In the pic you can tell it has a lip on the bottom that will seal with the gasket, on the top you can see it is ground just about flat with the flange.
What should i do? am I over thinking this?? return or install?
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
see here.. its ground to much.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
all the other look good like this
Should seal fine.
They make two header styles though, the ones you have install easy but will hang a little low and rub the front shackles. Just be prepared to put a ratchet strap around them and bend them in a little. Not a big deal really.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
They look fine to me as well. My headers fit great and sealed without any problems and mine are just like those.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
I called Hedman and sent them pics. (OMG i dont know how those passed QC)
were is exacted words. Those will give you problems every time you replace gaskets. Please send them back for replacements!! I am sending them back. He said the surface should all be the same and flat, not ground at an angle. thanks for every ones reply!! :cheers::gathering:
MadOgre
NA
NA
NA
NA
NA
LOL :) Good thing you got your issue fixed !
tonyo205
