hardware kit for exhaust manifold
fish on
Harrington, De
Phil
V20
Does anyone know where i can get an entire mounting bolt kit for the exhaust manifolds?
Swims350
Logan WV
none
lmc has collector bolts not sure about top side/head side ones.
Are you putting stock manifolds on? If so are they cast steel, or the type made of stainless shaped/welded tubing?
Or, are you looking for a header/head bolt kit?
Along with 7 regular bolts, a real OEM exhaust bolt set comes with one (or in some cases 2) shoulder type bolt. These are the ones that are used in the forward most holes on each head.
The left side shoulder bolt is used to mount the P/S bracket on all applications. Also, if there is a air pump(s) involved one is required on right hand side.
fish on
Harrington, De
Phil
V20
stock manifolds (cast steel) and air pump on the right front bolt.
Misty Blue
