Guess The Tool
Keith Seymore
Motor City
Keith Seymore
4.3L
Placing the tool in the teeth of the flywheel and wedging it against the transmission dowel pin keeps the crankshaft in an assembled engine from rotating, while torqueing the harmonic balancer bolt or using the aforementioned compressed air in the cylinder.
K
Keith Seymore
Motor City
Keith Seymore
4.3L
Here's a couple easy ones:
Moderator
Slide hammer and seal driver?
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I'm guessing driver for freeze plugs or the welch plug for the camshaft.
yevgenievich
Place
Name
Year
Model
Size
This is interesting one, not for a vehicle.
Edit:
Small radiation detector for inspecting the back of an eye.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I think my dentist has one of those.
Keith Seymore
Motor City
Keith Seymore
4.3L
Pretty close -
I am guessing that the slide hammer has a specific purpose?
Yes - it is used for pulling the rear axle carrier out of the housing on a Pontiac rear. Attach the countersunk hole to one of the ring gear bolts and slide away!
(Dad always called it a "whopper knocker").
The second one is for installing the pinion bearing on the gear.
K
Keith Seymore
Motor City
Keith Seymore
4.3L
Were getting down to the tough ones now. This one I suspect you will never get. (Just because there is not much to it, and its geometry really doesn't give much of a clue as to its specific purpose) -
Derrick
near Milwaukee, Wisconsin
Derrick
a small piece of round stock. lol
78C10BigTen
pennsylvannia
C10 BIG TEN
Since everyone wants an easy one....
Keith Seymore
Motor City
Keith Seymore
4.3L
That's what it started out as...
(lol)
Actually - I think it was a big socket head cap screw that has been turned down to a specific diameter.
K
NateP350
