grille replacement recommendations
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I'm stashing the original grill and bezels until a later when I have more time to properly prep and paint them. I'm looking for something quick, easy and relatively cheap to stand in their place in the meantime. I've done a quick query on the interwebs and see there are many options for aftermarket replacements. I usually default to summit, as I've had mostly good experiences with their customer service thus far. I was looking at a Goodmark grille and Sherman bezels. they're really cheap. only about $60 for all three plus an extra $20 shipping on the grille due to it's size.
are these units complete garbage? does anyone have 'em? any suggestions otherwise, keeping in mind I'm just using them for around a year until I get around to restoring the originals?
TIA
yevgenievich
Place
Name
Year
Model
Size
I had the cheaper version of those on 85 and it was ok. The cheapest 89-91 bezels that I found new were nowhere close to fitting.
To ensure they fit right, the grill should match the steel brackets mounted on your truck.
My OEM '75 brackets would work with an original grill, but '75 grills are are hard to find. The grill I found from about a '79 fit in the opening, but screws did not line up. I had to go back to the junkyard and pull the mounting brackets from the donor truck because nothing would line up with my stock '75 brackets.
Apparently the '75-'76 GMC grilles use the same brackets as all the '73-'74 trucks, and the '75-'76 Chevy grilles use the same brackets as all the '77-'80 trucks.
TIA
I've installed the same style aftermarket grilles before. The fit was decent. They were from a local auto body supply store, so probably Tong Yang brand. I'd bet the farm that all the Goodmark, Sherman, LMC, etc truck grilles all come from the same supplier. I used to get them locally for about 30 bucks too.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
I have a replacement headlight bucket, and original buckets. THe originals are pot metal and solid, the replacements feel like dollar store alluminum pans. THey are absolute trash compared to OE, although it fits the truck and does the job.
Grille, for me, my 79 repo grill has no bowtie or provision for one, otherwise it fit fine and again, did the basic job.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Thanks for the replies. I got tired of my harbor freight media blaster making a mess and clogging frequently. I may just get the “commercial” blasting enclosure and a better blaster. I really like baking soda for softer parts like plastic, but it can be a pita. Unfortunately, my grill and bezels have argent silver gooped over the original green. They need to be cleaned up a bit before I can paint them.
carlgm
Fl
Karl
'85
If you bought one, please post a short review. I'm curious about its quality and fit.
twzorek
