Gas tank brackets
cdmoore91
Pimlico, SC
chad
Ordered some new gas tank brackets off eBay and tried to install them last weekend. The new brackets don’t have nuts welded on the inside of bracket, and the holes also didn’t line up on the front bracket.
Does anyone know of a place to order some oem style brackets?
ozone160
Colorado
Geno
Not many in stock tho
waterpirate
delaware
v10
5.7 tbi
Just did my 87. Pay attention to which set of holes the straps go in. Ask me how I know, lol
HOTFOOT
northwest ct
michael
gmc k3500 srw
no one is going to have ones with the nut welded on!
Washington
Have you exhausted efforts to find used OE brackets?
cdmoore91
Pimlico, SC
chad
From the pics these don’t look like the have the nut welded on either.
cdmoore91
Pimlico, SC
chad
I did t pay much attention when removing them like a dummy. The front bracket has two holes for the strap, so of course I tried the top one and the stud would hit the Frame and not line up with the hole that’s in the frame. So dropped the tank again and tried to get the strap to go into the lower hole with zero luck! Said screw it and put the original ones back on.
cdmoore91
Pimlico, SC
chad
This is my next step. Trying to track down a junker around here that’s not demolished should be fun
hoagster
California
K10, 1500
5.3l
Do you need the frame bracket or just the straps? I have an extra set of straps if you want them.
pm me and I'll send them to you they will just collect dust in my barn.
hoagster
California
K10, 1500
5.3l
New brackets don't come with the weld nuts on them. I had to drill one hole I believe on the front bracket for the drivers side tank. My truck had the primary tank on the passenger side only.
waterpirate
delaware
v10
5.7 tbi
Bingo! My experiance exactly. I was able to undo my mistake however and get the new straps into the old brackets. I used pop rivets for a newer cars window regulators to secure the straps to the brackets. 1/4 inch I think with the big washer on them.
cdmoore91
Pimlico, SC
chad
My straps are good, the brackets are what’s rusting
scrap--metal
MN
Calvin
'85, '81
K10, K20
Just use nuts with lock washers on the inside of the brackets. It's kinda a PITA, but it works just fine. Hold a nut in a box end wrench with one hand and tighten the bolts with the other hand, while the empty tank is supported by a jack.
The holes will line up with the frame. Pay attention to whether you're using the frame holes for the 16 gallon tank or the 20 gallon tank. The gas tanks and brackets should sit a little lower then the frame rails.
scrap--metal
MN
Calvin
'85, '81
K10, K20
Also valuable advice. Been there, done that, too!
Twistedwhisky
