Fuel pump in tank w/carb
Dave C.
Hamburg, NY
Dave
Anybody here know what it would take to run a stock Blazer fuel pump in the tank with a Rochester carb? I have an electric fuel pump I would like to eliminate as it is pretty noisy. Since I am attempting to install a Blazer tank in my C10, I thought of using the '89 Blazer fuel pump and sending unit as well. I cannot use a mechanical pump as my block is a '99 which is not machined for a pump. Any advice is appreciated.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
You just need to have a fuel pressure regulator in line before the carb, regulated to about 7psi or so. A quick search on Summit or Jegs should pull up quite a few for a reasonable price.
Dave C.
Hamburg, NY
Dave
Ok, That should not be a problem then. I was just worried that I would need a return line.
Thanks!
alwaysbroken
