Front sway bar bushing replacement
dhenderz
Michigan
Dennis
Has anyone found an easy way to replace the bushings on the front sway bar on these trucks? I am not talking about the center (fwd) 2 bushings that the bar pivots on. Those are easy. I am talking about the 2 that are press fit into the ends where the bar is bolted into the leaf spring brackets (at the axle).
Here are the ones I am talking about -
I had to burn & drill the old ones out of the bar. These new ones (AC Delco brand) appear to be at least 1/8inch in diameter larger than the hole in the end of the bar.
Craig 85
Nashville, TN
454/TH-400/NP205
I don't know if your truck is lifted, but on my last 2 trucks I've run ORD's sway bar disconnect kit. It really improves the ride. You need 2" of lift to run them. They also sell replacement bushings.
https://www.offroaddesign.com/catalog/swaybarkit.htm
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
cant comment on the acdelco brand. When I replaced all my bushings I went with ORD stuff as well. everything seemed to go in easy with some grease. Then again, two piece polys are a different situation than rubber oem type.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
You just need to get really angry putting them in... with a press.
Twistedwhisky
