front suspention travel
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
is it just me or do squares have terrible suspension travel up front? stock i had about an inch till it hit the bump stops, and with the 2 inch lift i have 3 inches, but thats when the shocks fully compress, i gotta change the bump stop setup. but anyways what do you guys have as far as compression goes?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
I have 6" lift but only get maybe 4" or so of compression, maybe a little more. Axle droop, that's another story. I can probably get close to 10" of droop. Add that to the compression and 12-14 inches of front travel aint too bad! I should get the tape measure out sometime and find out exactly what I get front & rear, might be more than I think.
Your extra two inches comes from added leaves, right? That could have a lot to do with your lack of travel.
This is my Burb with 4 inch springs and sway bar still in place:
Probably 9 or 10 inches of travel in those pics, but it may have some more in it. There's more down than up.
crazy4offroad
K-10
350/SM465/NP205
6" Superlift fronts driver side droop:
attachment.php
Same side compressed:
attachment.php
heavyleft
Fayetteville, NC
V10/K5
350ci
6" lift. I need to figure out compression on my rig also.
Sitting flat
Front as stuffed as it gets
Dropped out to the Max.
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
whoops i was only asking about compression, yea i get a ton of droop too so theres a lot of travel, but hardly any compression. i may even need limiting straps...
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
yea its added leaves
wheelerboy12
Dundee, OR
jeremy
i have a lot of flex and mine is stock suspension with 33 inch tires and cut fenders... i want to make brackets to change my shackle location so its at a 45 angle instead of straight up and down lol. i have a pic on my phone and ill get it uploaded in a few more minutes
wheelerboy12
Dundee, OR
jeremy
heres the picture!
i still have a lot to go but my jack ran out of up travel lol, once i get it registered and plates ill take it to my school where we have a loading ramp that we like to flex our cars on and ill see what it can actually do.
edit: im not sure if its working, its not showing it on my end, if its not showing let me know and ill try and fix it
heres the picture!
Hahahha, that's the first time I saw a jack under a tire like that. :roflbow:
wheelerboy12
Dundee, OR
jeremy
haha yea me and my friend were bored one day and decided flexing it would be fun, but since it does not have plates i cant leave my yard with it so we got inovative lol
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
thought id put some pics flexing too
attachment.php
attachment.php
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Probably shouldn't give you any ideas.
When I bought my truck in June I couldn't afford all the fees up front so I went to the DMV and got it transferred into my name and insured. The gal asked if I wanted a one-day pass. I declined but then said yes. She showed me what I needed to fill out, and the main thing was the date. I drove it to the dump a few times, some lawnmower races, etc. I just kept the paperwork with me in case I got pulled over. So if I did get pulled over I would fill in the date really quick. Never had to do that, but 2.5 weeks later I got the plates and such so it didn't matter.
