Front leaf spring bolt
ford
Austin, TX
Michael
Sierra Grande K15
Looks like the standard across many trucks is to cut them out when they get rowdy and stuck. Considering the level of rust I'm battling for this frame off resto, I want to cut mine to install new leaf springs on the front.
Rear bolt on the leaf soring came out easy peasy. The front....even the sledge doesnt budge it. Problem is, WHERE THE HELL. do I buy new bolts at? I don't see them online. Even on rock Auto I thought I found it but the picture was of a u bolt.
Can anyone help? If you need a picture i can supply one.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
You're talking about the bolt for the leaf spring mounts at the front of each leaf pack?
Checking Rockauto for you, it should be the same as the listed shackle bolts.
9/16" x 4.5" or 5"
http://www.rockauto.com/en/catalog/...+v8,1157015,suspension,leaf+spring+bolt,10353
At diy4x.com, you can order a set of greaseable bolts to make it ride a little bit smoother.
http://diy4x.com/product.php?productid=17724&cat=0&bestseller=Y
Same with ORD,
http://offroaddesign.com/catalog/bushingassemblies.htm
ford
Austin, TX
Michael
Sierra Grande K15
Thank you. I think ill go with the DIY ones.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
More than likely they are the 9/16" bolts, but make sure to double check before you order.
ford
Austin, TX
Michael
Sierra Grande K15
At those prices I'm half tempted to buy 2 in each size just so they are waiting when I get back to town .
wamullins
Bryant,Al
Anthony
C-10
I got mine at Lowes, 9/16x5 grade 8. They were just a little over $4.00 each.
ford
Austin, TX
Michael
Sierra Grande K15
I lied. Got the Rock Auto ones. I liked the ones from ORD but their shipping prices just were insulting for the bolts.
There are some things I don't mind spending money on but some things that just hurt my sensibilities. I'll pay $1500 for a TV or a turbo or something, but ill be damned if i'm paying $15 for some body soap or something. :D
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
ORD has some really nice things, but their shipping is quite high. I try to make sure to get everything I need at once instead of numerous smaller shipments.
wilson79
