MrMarty51
- Oct 25, 2012
- Eastern Montana
- Martin
- K20
Has anyone ever seen anything like this???
Rebuilding this 14 bolt front differential/axles,got the knuckles off and found this in the right side upper ball joint instead of the threaded adjuster.
I tried to find an oversize balljoint adjuster that could possibly replace this thing by threading the egged out hole and installing an oversize adjuster.
Has anyone else had this problem and if so how did You get it remedied.
If there is no other fix I will use this thing but I dont think the turning torque of the knuckle would be correct.
This center hole in this thing is offcenter to allow for camber/caster adjustment.
Thank You in advance for Your replies MrMarty
