Frame questions
Juniarsc10
Tx
Miguel
So I have a 1983 c10 lowered 5/7 new brakes,spindle,springs,ball joints
Rear flip kit....But after install I found out the frame is bent now I know
The 81-87 frames are the same but was wondering if I could also
Use a frame from a 73-80 and strip it re-plum it (gas and brake lines)
And just swap all the suspension over if I just modify the body mounts
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
73 to 80 frames use different rubber body mounts then the 81 to 87 frame does
use the matching rubber or poly body mounts for the year of frame and the body is a direct bolt no modifications needed
but the front bumper mounts different you will need to modify the front frame horns
Juniarsc10
Tx
Miguel
So what about suspension parts
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Minor differences here and there, but your drop parts should work fine on any frame.
bluex
Spartanburg SC
C15
The only difference is the idler arm an bracket between those years. As long as you know which set you used so you can replace it later on you'll be fine.
spartantx117
