Vbb199
B-rate Hillbilly Customs
- Jan 12, 2018
- Salisbury NC
- Vince
- 89 Suburban R1500, 79 C10, 99 Silverado
Greetings all, kinda new here, made a post over in the "under construction" forum for my k5, running heavy tires 53", or tractor tires, 5 ton axles, big block power, etc. Looking to box the frame, in the process of removing the body from the frame, and then I'll begin welding the frame, welding on a sub frame, dropping a motor in, axles, transmission, drop transfer case, blah blah blah.
Anyways, about boxing the frame in, for any of you guys out there that's done it, how did you do it? Send pics, what size steel did you use? Did you do front to back on the rails? Or just the center section and no so much the back half and the front engine half. Looking for recommendations on my build, just trying to see what's worth doing, and what's a waste. Instinct is to weld the entire frame closed into a box with 1/8 plate front to back, then build the sub frame under it for the drop transfer case I bought.
Thanks guys
Sent from my SM-G965U using Tapatalk
Thanks guys
