1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
1974 2wd crew to 4x4.
Discussion in '2wd Pick-Ups C/R 20 2500 C/R 30 3500' started by climb-101, Apr 3, 2018.
  1. climb-101
    climb-101 Full Access Member
    258
    271
    Mar 12, 2018
    montana
    First Name:
    seth
    Truck Year:
    974
    Truck Model:
    c2 crew cab
    Engine Size:
    6.0 LS
    got the rear bumper all welded together. once that wa done i ground down all the welds then sanded the whole bumper with a da sander to blend everything really well. Also got it mocked up on the truck and tacked into place.
    only thing i don’t like is that the way the brackets to the frame are designed. they hit the back lip of the box on my setup. i’m not sure if all the trucks are this way or not. ill get some pics later. i ended up notching the bracket. the down side is that i will have to lift the box up about 1.5” in order to slide the bumper out. I figure it’s not a higher deal since i don’t plan on taking the bumper off too many time.
    foamypirate, Old77 and ajd89 like this.
  2. idahovette
    idahovette Full Access Member
    72
    3,005
    4,297
    Aug 7, 2016
    Weiser Idaho
    First Name:
    Perry
    Truck Year:
    1975-1979
    Truck Model:
    K20-K10
    Engine Size:
    It looks really good!
    Old77 likes this.
  3. Blue Ox
    Blue Ox Turning Diesel Fuel Into Fun
    3,184
    5,329
    Mar 27, 2018
    LI-NY
    First Name:
    Derek
    Truck Year:
    Truck Model:
    K20HD
    Engine Size:
    6.2L
    Really nice fabricating, and it does look good.
    But I hope you're not planning on using it as a step anywhere but in the middle.
  4. climb-101
    258
    271
    Mar 12, 2018
    montana
    First Name:
    seth
    Truck Year:
    974
    Truck Model:
    c2 crew cab
    Engine Size:
    6.0 LS
    there is room if you want to step on the outer parts. more than it looks like in the pics
  5. climb-101
    258
    271
    Mar 12, 2018
    montana
    First Name:
    seth
    Truck Year:
    974
    Truck Model:
    c2 crew cab
    Engine Size:
    6.0 LS
    got the front bumper all mocked up and tacked together. i ended up cutting the frame mounts a little and welding a plate to them. that way the frame mounts also tie into the B52 brackets. i have a warn m12000 on the way to try to get behind the bumper.
    now it’s time to weld everything up and spend a few hours grinding and sanding/blending everything together. also have to get the winch mounted and tow hooks welded on the bumper.
  6. dvdswan
    dvdswan Full Access Member
    1,614
    1,085
    Mar 11, 2014
    Port Orchard, WA
    First Name:
    Dave
    Truck Year:
    Truck Model:
    Engine Size:
    That's got to be a heavy bumper. Stout for sure.
  7. Frankenchevy
    Frankenchevy Lying Dog-Faced Pony Soldier
    4,832
    5,044
    Jan 3, 2018
    First Name:
    Truck Year:
    Square
    Truck Model:
    CUCV
    Engine Size:
    Small
    This thread is motivating! Awesome job
    climb-101 likes this.
  8. Boonie
    Boonie Full Access Member
    50
    285
    119
    Jun 3, 2013
    El Dorado, KS
    First Name:
    Brent
    Truck Year:
    Truck Model:
    Engine Size:
    ive looked into those bumpers for the dually. those look great, definitely getting one now.
  9. climb-101
    258
    271
    Mar 12, 2018
    montana
    First Name:
    seth
    Truck Year:
    974
    Truck Model:
    c2 crew cab
    Engine Size:
    6.0 LS
    the bumper is prob 100-120 lbs if i was to guess. the center is 1/4” thick and the outer part is 3/16. by the time i get the winch and tow hooks on it i would think that everything together would be around 250 lbs.
  10. White85
    White85 Full Access Member
    65
    62
    Dec 21, 2018
    Washington
    First Name:
    Kevin
    Truck Year:
    Truck Model:
    Engine Size:
    Very nice bumpers and truck in general!
  11. climb-101
    258
    271
    Mar 12, 2018
    montana
    First Name:
    seth
    Truck Year:
    974
    Truck Model:
    c2 crew cab
    Engine Size:
    6.0 LS
    had to do a little modification in order to get the bracket for the twin stick setup and the 205 case support to work together. I got the support clamped in the mill and notched the ring .25” deep so the corner of the twin stick cable bracket would fit.
  12. climb-101
    258
    271
    Mar 12, 2018
    montana
    First Name:
    seth
    Truck Year:
    974
    Truck Model:
    c2 crew cab
    Engine Size:
    6.0 LS
    i had to pull the cab again today. in need to do some header fitting and get some broken manifold bolts out.
    here is how i did the manifold bolts in case any one is ever looming to do it.
    both bolts are brok off 1/8”-3/16” into the hole. i used my tig and some stainless rod to weld onto the broken bolt part and started stacking the bead up until i was about 1/8” past the head surface. once i was out that far i could put a stainless nut over the beads and tack weld it in place. I continued to fill the center of the nut while i welded it to the beads i had sticking out off the bolt. i let it cool down just a little and used some PB blaster while it was still hot so it would suck some into the threads as it finished cooling. then i just used a wrench and worked it back and forth a little until it came out.
    Catbox likes this.
  13. climb-101
    258
    271
    Mar 12, 2018
    montana
    First Name:
    seth
    Truck Year:
    974
    Truck Model:
    c2 crew cab
    Engine Size:
    6.0 LS
    spent some time working on getting the warn m12000 winch tucked in behind the bumper. it’s a super tight fit since the winch is so large. i ended up swapping to a shorter motor (same hp though) and trimming up the frame a little to get everything tucked in place. should be a nice clean install when it’s finished up.
    Catbox, ajd89 and B.K. Cunningham like this.
  14. climb-101
    258
    271
    Mar 12, 2018
    montana
    First Name:
    seth
    Truck Year:
    974
    Truck Model:
    c2 crew cab
    Engine Size:
    6.0 LS
    got the front part of the stainless exhaust done on the truck. now i need to figure out a quiet muffler for it. i used the speed engineering short headers. the drivers side just needs a 45 and 90 bend to get it down to where i could run the pipe just in front of the pan. the passenger side i had to add in the header a little to get the v-band where i wanted it and the pipepointing the right direction. i built a merger for the 2.5” pipes from both sides into a single 3” also
    Catbox, ajd89, Craig 85 and 3 others like this.
  15. NotKewl
    NotKewl Junior Member
    15
    11
    Jan 23, 2019
    Chattanooga, TN
    First Name:
    Brent
    Truck Year:
    Truck Model:
    GMC
    Engine Size:
    5.9l
    Nice build. Thanks for a proper 4x4 conversion. I'm planning on doing the same thing. I've built many rock crawlers and competition offroad vehicles, but this will be the first time I convert a road vehicle to four-wheel drive.
Share This Page
