four headlight truck?????low/high beams
yevgenievich
Place
Name
Year
Model
Size
89-91 headlights are wired using smaller wiring and splits. But I had a case where I was using 89-91 harness on an 85 truck with regular set of 4 headlights and it became with low beam off when high beam is selected. Did not get a chance to ever install relays.
charlesg
wisconsin
charles
k3500
Yours seem to be split and not set up for four lights to be on. What year is it? The best way would probably to install relays to trigger from headlight switch and wire the lights to be on with high beam. But on regular 88 and earlier four headlight set up there is a green wire and brown wire connecting to low beam light. It lights up differently with high vs low
My truck is a 91
yevgenievich
Place
Name
Year
Model
Size
My truck is a 91
Then it is correct factory operation. If you want low to stay on then need to run relays for the headlights and use a diode to feed the low beam relay from the high beam control wire.
hawk630
Washington
I really like your headlight schematic. Do you have any more of the wiring.
1985 truck with 91 electric doors
Rick near Seattle
73c20jim
Sierra Vista, AZ
C20 2WD Custom Deluxe
350 CID 195/260 HP Goodwrench crate
Go to Reference section. All the wiring diagrams you'll ever need.
charlesg
wisconsin
charles
k3500
question, I got a relay but it has a 87a plug, along with the others, can I still use it??
yevgenievich
Place
Name
Year
Model
Size
Yes, the terminal is just not used if not needed.
Daveo91Burb
Vancouver, WA
Dave
V2500 Silverado Suburban
Vortec 383, modified TBI/4L80e
Do you need to use a diode? I've had mine wired for years with just using a relay in between lows and highs - when highs are on, relay is triggered to feed the lows. When just the lows are on, relay acts as just an open switch. It's worked well for a couple of years, no diodes to mess with. I DID use the diode trick years ago on my '89 K5, but it was finicky, probably my lack of care, money and time as a college student was more of a factor, though.....
yevgenievich
Place
Name
Year
Model
Size
The relay is fine. Diode was just a simple to add option
charlesg
wisconsin
charles
k3500
I did this conversion yesterday, way cool! Thanks for all the help all yall.
Scrambler-Cafe
