Footwell, rockers and cab corner replacement
Manny84
Canada
Carson
1500 4x4
Hey guys, I have a 1984 Chev 4x4 that I’m currently fixing the rust on. Just wondering what you guys would suggest in the order to put these new patch panels back In for footwells, floor, inner and outer rockers and cab corners. Also any other advice to make the process go smoother as this is my first kick at the can for doing this. Thanks
Chevy 88
Canada
f7t6
GMC
Holy crap, I have never seen someone eat an entire steak in one bite before!
I think you bit off a lot on this one.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Looks like you'll need kick panels too.
Id probably start with kick panels, inner rocker, then outer, then floor. Best to fit things together before welding anything solid to make sure your alignment and door gaps remains correct.
1STLS1
West Phoenix AZ
MIchael
This
Fit everything with pop rivets, Cleco fasteners or weld tacks. If you're fitting all new aftermarket fenders, doors and rust repair pieces, it's not going to be an easy job. I would almost want to use the rusty OEM sheetmetal to get the rocker and cab corner lined up together before trying to install and fit the aftermarket sheetmetal just because of how much they often need massaged to fit to begin with.
I hope you have some MIG or TIG welding skills welding thin sheetmetal.
69project
North Carolina
Lee
3500HD
6.6 Duramax
Youtube is your friend. I am just finishing up this very job. I am a complete novice at this but I would work from the outside in, meaning install the outer rocker panel first. Then do the kick panel, inner rocker, and cab corner. After that then fit the cab mount brace and cab support. I would to the floor pan last. The guy in this video gives a couple of methods to ensure the door still fits. If you have not bought the sheetmetal yet, I recommend TABCO. They claim to be US made and they are definitely thicker than other vendors selling metal. I have bought sheetmetal from NPD and TABCO for my project (85 K10 needing rockers, floor pan, cab corner, etc) and the TABCO metal was superior in my opinion. None of it fits perfect so get used to using a hammer and slicing some of it before putting the welder to it. Good luck with your project. Take your time and don't get in a rush.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
I would get the cab off the frame. You will need access underneath to do a decent job. The key as was mentioned above is tack weld everything in place then make sure your door gaps are good. One that is the case you can weld everything in place. Do small areas at a time to limit the amount of warping you get from the heat.
I have my 1987 at a restoration shop. He replaced both rockers, inner and outer, small area of the floor, cab corners and inner kick panels. I bought one rocker NOS and the rest of the stuff came from AMD (Auto metal Direct). The body guy said the AMD stuff seemed to be the same thickness as original and it fit perfect. There is always a bit of massaging required. Remember these are mass produced vehicles and "good enough" is how they built them.
FWIW I had to replace one door too. I bought an NOS door and in hindsight I should have bought a used rust free door. The tweaking the NOS door needed to fit right was unbelievable. Rust free door and sand blasting would have actually saved me a bit of money.
Manny84
Canada
Carson
1500 4x4
Thanks for the reply and advice
mano
Florida
mano
I had to do the same thing to my 79. You can’t start from the outside in. With it cut apart like that, you’re going to have to pull the
back of the cab in. The cab flexes a lot . You can use a ratchet strap from the door hinge. If you don’t you’ll have a hard time fitting the rockers. I find it easiest to screw it all together with self tapping screws. Once everything fits good start welding
75BEASTK20
B.C. CANADA
Cal
WOW ! That looks about where I am at with mine now in the garage. Scary, isn't it? Here's my BEST advice (after throwing tools, busting ****, and almost divorce). GO SLOW. TAKE YOUR TIME. USE sheet metal screws AT FIRST to tack the rockers etc. in place. PRACTICE on some spare metal for MIG or TIG. (I use MIG). It's an art. Just practice.....get your heat settings right.......don't race with the MIG. It'll come together. SLOWLY. I tell myself if I just get ONE panel done a day, that's ok. Mind you, it is getting pretty damn cold out there now !
Even WITH my big heater in the garage. Good luck to ya. She's a beast.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
I agree with the others, kick panels, inner rockers, outers, floor last.
1 thing I'd suggest though, is to hang a door and a fender, and pull the cab to get the gaps where you want them before screwing anything together.
Johns C10 Hubcap
