Foamy oil
Copper Jr
Missouri’s
william
I'll suggest something no one has suggested : how often do you drive it?
Do you just fire it up and drive it down the driveway the shut it off?
running the engine for short periods of time then shutting it off causes condensation in the crank case and motor.
Yeah since I’ve been working on it I’ve only been starting it up, after I change the oil I’ll be driving it 20 miles daily so we will see if all this helps then last case go for the head gaskets
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
In the past I've mistaken head gaskets for just poor engine heat cycles in a old mud truck I had.
Just a thought
Vbb199
Salisbury NC
Vince
All oil looks good, nothing in the pan. I still ordered a new pcv but I’m thinking it was the short cycling. I’ll update after a couple long drives.
Awesome
Rusty Nail
Cowboy of both Time and Space
Russell
350sbc
Yes change it.
5 bucks.
That slop is just from sitting around, your head gasket is probably fine.
CONDENSATION does that.
The weather.
Are head gaskets an easy job? And any brand recommendations?
Not easy.
Many recs...
Camar068
Air Force Supporting Member
10 yrs Air Force
That's what an oil catch can takes care of. That's why I mentioned it and why I put one on mine.
Vbb199
Salisbury NC
Vince
Copper Jr
Missouri’s
william
Replace pcv and took a nice long ride, no more foam
Salty Crusty
Gary
c1500
Sounds like you dodged a bullet, good for you!!!
ozark plateau
dennis
k5
while you are in happy mode, change your thermostat. 195 or 210. and the short trip thing as was said above. you gonna kill your lifters if you keep it like it is.
bajadiver
