Fix this Paint? Any ideas that I do not have to repaint the whole Suburban?
Woodman77
Idaho
Woody
Suburban chevy
Sad Sack
Nebraska
Goober
C15
In order to make it right, the clear has to be removed, then normal paint prep from there on in, many reasons this happens but the the repair is as basic as it gets.
Woodman77
Idaho
Woody
Suburban chevy
Thanks SACK,
So a major repaint?
Sad Sack
Nebraska
Goober
C15
Thanks SACK,
So a major repaint?
Looking that way. You could try just repainting the defective panels, but color matching may be an issue and I wouldn't hold much faith for unaffected areas if they have the same clear coating. I have dealt with that same issue on a 3rd Gen Camaro when I worked at a body shop years ago and it was a nightmare, the corrupt clear couldn't be feathered to respray, it just kept releasing chunks when trying to sand the clear down. That's the car that made me say I'll never do another one unless it's a complete strip and respray. Good luck.
Woodman77
Idaho
Woody
Suburban chevy
Thanks Sack.... I was thinking that may be the future.
My truck is doing the same thing, the clear is slowly flaking off. I'm just letting it do it's thing. I'll go back and polish the uncovered areas and flake it back to where the clear is more solid so it looks decent. Then it'll go a while and grow some more, I'll do it all over again. Hoping that eventually all the clear will just come off and I can cut and buff the basecoat underneath lol
Woodman77
Idaho
Woody
Suburban chevy
Thanks Huck,
I suppose I could get good at that process.... If I can Live That Long...
Sad Sack
Nebraska
Goober
C15
You could speed it up by blasting it with a 4000psi pressure washer, that'll send sheets of clear flying, guaranteed.
The Right side of Washington
Ah the infamous GM peeling clearcoat.....
Nope
My truck is doing the same thing, the clear is slowly flaking off. I'm just letting it do its thing. I'll go back and polish the uncovered areas and flake it back to where the clear is more solid so it looks decent. Then it'll go a while and grow some more, I'll do it all over again. Hoping that eventually all the clear will just come off and I can cut and buff the basecoat underneath lol
Base coat doesn’t shine up. And it is or it should be effectively to thin to even try it without burning through.
Sad Sack
Nebraska
Goober
C15
Nope
Yes sir, the whole clear coat peeling is a bodymans nightmare. But on the other hand, it gets one to appreciate the value of a good orbital sander or liquid paint remover.
While that was certainly an issue back in the day, 99.9% sure that is not original paint.
It could be, I suppose, but that funky pinstripe with the witness marks under the paint from the old original wide striped pinstripe decal and the sagging base coat under the window trim in the door suggest otherwise.
GM did start switching to 2 stage paint late 80s and this truck being an 88 it’s possible? My first ‘90 GMC pickup was 2 stage but I don’t know when or if they even switched on the late model squares. 1986 squares are still 100% single stage paint.
Nope
I say base coat, it's single stage under there. They cleared the truck when they cut it down cuz the flipper I bought the truck from loves clearcoated patina
jw23655
