Fix Slamming Doors - Striker Door Latch Repair
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Not sure if the Suburbans are different from the crewcabs, but I was able to get access to the backing nut after removing the B-pillar trim...after I dropped the nut down the pillar, lol. I tried to hold it in place with a magnet while unscrewing the striker. It didn't work. That sucker dropped like a rock! Had to pull the trim, and use the magnet to reach down to the bottom of the pillar to retrieve the nut. I would think the Suburbans would be somewhat similar.
Yeah I would have to assume they'd be similar too. I'll rip that trim panel off later this weekend and see what it looks like
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I did this just now in my Jimmy, and it helped a lot. I tried to do it in the Caprice, but the strikers are smaller, and the door just bounced away when I tried to shut it. Maybe quarter inch pex pipe?
Moderator Administrator
Yep, I'd try smaller pex.
75vette
Felix
Once you get it cut to where it can open up, simply open the piece and put it around the door stricker with the opening facing away from the latch. Very simple. Now close your door with just a little force and watch is shut nicely without slamming it. If it still does not work, then you have other problems like hinge pins or bad latch.
attachment.php
After you get the pex installed, your stricker will look something like this.
attachment.php
This works great and is a lot cheaper than replacement parts from LMC or anyone else.
75vette
Felix
I did this 6 months ago and it works great!
Don R
Kansas
Don
JIMMY
Thank you for the detailed tip. I had heard of this, but glad to see it actually done.
Carb'ed Vortec 350
Saw a guy over Thanksgiving weekend and told him about this and the site. Hopefully he joins. He had a nice rig.
shanegtr
Perth, Australia
Shane
R2500 Suburban
Thanks for the post, I have to slam the passenger door on my burb so I'll be defiantly looking at this.
You won't have to when you get this done. I normally keep a few of these pieces in my glove box. I've handed out and installed a few to other square owners I see and invite them here.
oldman
north fla
Ken
silverado 1500
lol not for nothing but zip ties work too
K201979
Winona, missouri
Hippie
350ci
I had some 1/2" cpvc laying around so i took my chances with it. Worked great! Passenger door is like new. Driver much better but i think pins are worn. Cpvc was a little harder to cut and spread open but it worked.
Pex treatment on all four doors :party33: they open and close like new now
Ken Beck
Salida Colorado
Ken
GMC C15
Welcome to the future! It's 2019 and I just now discovered this ancient artifact that healed my elbow from serious damage due to door slamming. I too now have 7'10 1/2" of PEX to donate to the cause. If you can find me, I'll likely share what would otherwise be wasted PEX.
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
I tried putting some cut 1/8" air line tubing on the rear barn door strikers yesterday but it didn't wrap around far enough. Got to find something a little bigger.
Bringing this back up. Did you ever find something to work on the rear barn doors? I'm going to get some pex for the 4 doors today, but was wondering if anyone has done something similar to the barn doors.
JMSYE
