Factory sway bar?
78C10BigTen
pennsylvannia
C10 BIG TEN
Saw this in the junk yard and wonder if its a jerry rig or a factory option. It was on a 77 c10, Plain jane truck. Any ideas?
ajd89
Central Michigan
andrew
Im guessing its factory. The one on my 87 R10 looked like that from what I remember.
K201979
Winona, missouri
Hippie
350ci
My 79k20 swaybar looks the same just diferent mounting(4wd solid axle)
78C10BigTen
pennsylvannia
C10 BIG TEN
Only time ive seen that kinda sway bar was on a 77 g30 value van. I thought about yanking it for my 78 c10 but wasnt sure.
Moderator
That's factory for sure.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
You can see the rivets for the mounting bracket on the frame.
Keith Seymore
Motor City
Keith Seymore
4.3L
RPO F59 Front Stabilizer Bar ($40 in 1987).
K
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
But the truck in photo was a 77. Anyone know if theres an aftermarket sway bar add on for a 78 c10?
Belltech 5404 is a bolt in direct replacement aftermarket unit.
Supposedly requires a Belltech 5704 adapter kit if you don't have a factory sway bar.
Gets outstanding reviews at Summit.
Keith Seymore
Motor City
Keith Seymore
4.3L
elcamman50
lakeside, california
charles
Found one in the junkyard here in San Diego. Used my battery grinder to grind off the rivets. It was a bolt on for my 79 Big Ten Short Bed. Holes are already there in the frame for the brackets. Just purchased some grade 8 bolts and nuts and hooked it up. Bought some polyurethane bushings since the original rubber ones were toast. Works like a charm and can really feel the difference in corners. Took this one off of a 78 C20 two wheel drive camper special.
78C10BigTen
pennsylvannia
C10 BIG TEN
I need one. I get alotta body roll
Moderator
My C10 doesn't have a sway bar either, and the shocks are worn. It sorta has that 'Caddy float' thing going on. It just gives it character, lol.
SLO-C10
Maine
I can vouch for this sway bar, I installed it along with the Belltech rear swaybar and love them. Bear in mind I was going from no sway bar to having both front and rear.
You do indeed need the 5704 brackets as well.
WyldTinker
