Exhaust smoke on startup
texasmike
Conroe Texas
The truck I have sat outside for 13 years before I started the resto work on it over two years ago. It has less than 53k miles on it and I noticed that on cold startup, it blows a lot of smoke out the exhaust that clears up quickly.
Is that something I should be worried about and how much would it cost to fix it? I'm pretty sure it would be too much for me to tackle on my own.
Scotty D
Convoy, Ohio
Scott
C10 Bonanza Big10
Most likely the valve seals are the culprit. It could come out of it the more you run it. If the smoke goes away after it starts is a good sign
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
Color of the smoke is important. Black smoke is too much fuel. Blue smoke is engine oil being burned. White smoke that goes away quickly is water vapor in the exhaust system. White smoke that hangs out for a while, and smells like maple syrup, is coolant.
Generally, if you're seeing blue smoke at start up, you have valve stem seals that have failed, and are allowing the oil sitting on top of the heads around the rocker arms and valve springs, to leak down the valve stems while the vehicle is parked. You could even have a failed valve stem, or more than one. Usually valve stem seals can be replaced in situ.
Rickf
Grafton NH
1974, 1954 & a 1937
I vote for valve guides and/or seals.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Valve seals more than likely.
Is your timing and fuel air mixture correct?
Curt
Loco Hills
Curt
K-30
Engines do not do well sitting.I would take the carb apart and clean.
Take a look at the plugs and timing as she suggested.Look at vacuum hoses,most likely dry rotted.
I only suggest it because I had an engine running super rich, super retarded and I thought it burnt oil profusely.
turned out it doesnt burn hardly any if any at all.
scawdrey
