Exhaust for tbi
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
looking for some exhaust ideas for my 87 long bed exhaust system. Anyone update the manifolds and exhaust system on a tbi? Not looking for anything crazy but I’m tired of the exhaust leaks on my rusty original system
Preston
Mechanicsville VA
Preston
I just installed headers on my 85 with new mufflers sounds great, got rid of all the exhaust leaks I’m still running a carburetor (replaced rogerchester with an edlebrock) eliminated a lot of vacuum leaks too. I really like the new sound went with megaflow rumble welded mufflers. I kept the pipes the same size as the collectors all the way back. So much for me good luck with your project.
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
Did you buy a exhaust kit or have a shop custom make one? I’d like to install it myself but don’t have access to tube bender ms and all that fun stuff
Preston
Mechanicsville VA
Preston
I used header extensions from headman out of the box came with the gaskets and hardware to connect to headers, drivers side a snap passenger side was tight removed the brace that was inside the frame rail. Bought the rumble welded mufflers and 4’ of straight pipe all from summit worked great sounds awesome
89squareburb
Burrton KS
Billy
R1500 Silverado Suburban
5.7L
89 R1500 350 TBI, stock manifolds, y pipe to full 3" mandrel bent pipe with catn delete, flowmaster delta flow 50 series, 90 out in oe location with 4" tip. Adding 3 wire O2 sensor, and Stainless steel shorty headers next. Flows great, sounds mellow at idle, and barks under load, or high rpm. Built my system here at the shop I work at. Any reputable exhaust shop should be able to duplicate easily.
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
Mine's a 454 TBI. I just replaced my old cracked and leaking factory manifolds with new replacement manifolds. I have the factory y-pipe with a simulated catalytic converter (because no emissions testing on pre-96 vehicles in NC) and a flowmaster RV style muffler. She idles nice and low, and when you get on it, she'll let you know.
Catbox
Peter
C20 Silverado Camper Special
I see this is an old thread, but what the hay....
My 1995 Suburban still has the stock manifolds and Y pipe.
I have replaced the cat with a high flow one many years ago.
For the muffler I had a Flowmaster 40 series muffler put in to the stock location with the proper pipe extension to connect to the tail pipe.
Sounds good and was fairly easy to make happen.
