Engine
Engine will not run but about 15 seconds
  • Is this a fuel system problem
    Votes: 5 100.0%
  • Is this an ignition problem
    Votes: 0 0.0%
  • Is this an ignition switch problem
    Votes: 0 0.0%
  • Total voters
PVMChevyTruck
La Grange, Texas
4.1 litre
My 1980 C 10 with a 4.1 litre inline 6 will not run unless gas is pured into carburator bowl. Engine dies when gas is used up. Have good fuel pressure at carburator inlet. Carburator is a Rochester Varijet ll.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
You've answered your question and already trouble shot the issue.
It runs only with gas added, you're not getting enough gas through the carb.
omillan99
El Paso, TX
Oscar
K20 Scottsdale
350 4 Bolt
If you have pressure at the carb inlet then you'll have issues in the carb. Bad float, clogged jets but for sure it's in you carb.
TerColHan
Pasadena, Tx
Rod
Suburban 2500
Replace the filter stone in the carburetor inlet and see if that doesn't clear it up.
82SquareBurb
