Engine stumbles when you hit brakes even with vacuum for booster disconnected...
KRBishop
Boston, MA
Kyle
C10 Silverado
Have a 1984 c10 2WD that stumbles only while in gear and only when hitting the brakes. Originally I thought it was a vacuum issue, but I disconnected the vacuum line from the booster and it still does it!
The video below is the truck with the vacuum from the booster removed and plugged. The front wheels are chocked so the truck will not roll.
In park and neutral I have no issues... I can hit brakes and everything is fine.... When I put the truck in gear with foot OFF brakes... everything is fine... as soon as I touch the brakes it starts to stumble. Again, WITH the vacuum line to the booster disconnected and plugged.
I have since also disconnected the cruise control vacuum lines. So with no vacuum lines connected to the brakes (booster and CC) engine still stumbles only when in gear and only when foot on the brake.
1984 C10 w/ Power windows and locks, AC and Cruise Control... thank you in advance!!
gmbellew
Kansas city
glen
suburban 1500
there is a vacuum release switch that releases the vacuum in the cruise servo when you hit the brakes as a redundant feature. maybe disconnect that line from the cruise servo and plug it and see if that helps?
KRBishop
Boston, MA
Kyle
C10 Silverado
Cruise was next on my list! Where is the cruise servo located? Thank you!!
gmbellew
Kansas city
glen
suburban 1500
on my 1990 tbi 350, it is on the back of the block next to the distributor cap on the driver side. you wlmay have to take off the air cleaner to see it...
gmbellew
Kansas city
glen
suburban 1500
another potential option is electrical. you could have a short to ground in the brake lights or several circuits connected from mice chewing. I had that problem with some window/lock harness mice damage. it also caused a stumble when you hit the window switch and pegged the volt meter.
KRBishop
Boston, MA
Kyle
C10 Silverado
Connected battery to multimeter...
  • 12.83 with motor off
  • 14.3 with motor running
  • 14.3 with motor running and in gear with brakes pressed and engine sputtering
I also disconnected cruise control vacuum and the booster vacuum so the brakes are not connected to the vacuum lines at all. See pics below.
I am at a loss...
gmbellew
Kansas city
glen
suburban 1500
i don't know, man. somebody smarter than me will hopefully chime in.
Where were you testing voltage at? Are you testing at the distributor? That's most likely the circuit where you are having the issue.
KRBishop
Boston, MA
Kyle
C10 Silverado
I was testing directly at the battery. How would I test the voltage of the distributer using a multimeter? Thank you.
talltidefan
US
Butch
K5 Silverado
I read on one of these threads........
When cranking hold foot on brake, if it depresses down when cranking the brake vacuum booster is bad.
Keep us posted on results
Sent from my SM-A102U using Tapatalk
Not trying to be sarcastic but..... place multimeter lead on the Batt+ wire on the distributor and the other lead on a clean metal surface of the engine. Then try One lead on the Batt + and the other lead on the ground wire from the distributor. It should be close to the same and also greater than 12volts. If you see it bouncing close to zero, or reading low, or getting two different reading between the two measurements, you found your problem.
KRBishop
Boston, MA
Kyle
C10 Silverado
Was trying to figure out how to
LOL All good! I was trying to figure out how to connect the multimeter to the alternator... I tried to poke through the line the line but would not hold... other kids than this that make it easier?
https://shop.advanceautoparts.com/p/innova-auto-ranging-digital-multimeter-3300/12071148-p
Waylon
Waylon
K1500
If you have some extra wire and crimp terminals, build yourself a jumper wire to test it. Just disconnect the B+ wire at the distributor, plug in your new wire and run it straight to your battery positive terminal. An alligator clip at the battery would be best. You will have to disconnect it to kill the engine.
bedwards
Adger, Al.
Bryan
c10 Silverado
Just a hunch, but take your connector off the brake light switch and see if it does it. You have cruise control in one of your pics and it turns it off with the brake light switch if I'm not mistaken.
Shak379
