Engine removal tool
Terry Wilkerson
Kansas
Terry
GMC 1500
What do you guys think of the carb mount plate for engine removal? I'd like to remove the transmission at the same time if possible.
Terry Wilkerson
Kansas
Terry
GMC 1500
Picked up a 1 ton with a 3 ton cyl. Truck has original cast manifold. Will be replacing with an aluminum.
Rickf
Grafton NH
1974, 1954 & a 1937
I've only used the brackets on the front & rear diagonal corners of the intake manifold. Sometimes using the end of the head or exhaust can mangle up the valve cover.
sidschev
Arkansas
sidney
c1500
short chain and a engine hoist in my case i have a 8x8 beam out side with a chain hoist
Old Guy Bill
KY
Bill
I’ve used a carb plate before, just make sure you use the correct length bolts for plenty of thread contact.
i prefer the two bolt brackets diagonally on the intake though.
fast 99
Spokane, Washington
Problem with using head attaching points they are diagonal unless 2 crossing diagonal chains are used. I have removed many engines like that when intakes have to be removed before the engine because of clearance issues or intakes were made out of plastic. Such as a V10 Ford van. When motor is angled down in rear, engine will be higher on one side or the other with 1 chain. I have never had a motor plate detach removing a big or small block by itself. However, using a plate on something heavier than normal [like a diesel] could be unsafe.
Bennyt
Surprise
Ben
I pretty much only use carb plate but it's difficult with the trans. I usually put 1-2 tie downs on just in case.
Also, the 1 ton engine hoists usually have a shorter boom than the 2 tons so they are sometimes not quite long enough.
FenderBanger
