atvrider85
- Jan 24, 2012
- Mt Hope Ks
- Bobby
- k10
I have a 86 K10 that has a 97 vortec 350 with a carb installed on it. Engine has around 50,000 miles on it. Last couple of weeks intermittently when the truck is at idle or at idle with the transmission in gear it will have a popping noise coming out of both exhaust pipes. I have changed plugs but i didn't change the wires, they are taylor 8mm wires. Vacuum gauge is pretty much steady with very little needle shake at 18 mmHg with the air fuel needles on the carb adjusted properly. Intial ignition timing is set at 10 btdc. The exhaust is long tube headers with 3 ft of pipe then a 40 series flowmaster. No major leaks in the exhaust. The engine runs great and i am having trouble track down the issue. Any thing i could be missing. Thanks for the help.
