Electrical problem
Chevyboy12
Brandon
Was working perfectly fine the other day , i have a brand new battery and starter . but now nothing at all works not even the lights what could this be?
1982 chevy c10 8ft bed , 350 engine, 350 tranny
MrMarty51
Eastern Montana
Martin
Them two smaller wires, the ones hooked to the battery terminal on the starter, along with the battery cable. Those are called fusible links, probably fried one or both of them, a lot of times caused by hooking the battery up backards, I know, been there, done that, but, only once, when I was quite young.
Chevyboy12
Brandon
What kind of fuse do they take ?
MrMarty51
Eastern Montana
Martin
Not a fuse, it is a smaller guage wire to give it a very slow burn rate.
Fuses blow way too quick for that application.
There should be a tag hanging on them that tells the guage of fusible link required.
You`ll need a soldering gun but, first check them to make sure thay are the culprit, also be sure they are attached behind the nut and that the nut is tight.
Get a test light and check for current at that junction block on the firewall.
When this happened to me it was the fusible link on the alternator to firewall wire. As soon I wiggled it the lights flickered on.
Posted From Hell
chengny
Why this:
Kind of sounds like there was something that caused you to replace the battery & starter - true?
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
corroition on battery termials. Help put a battery in my truck other day and it was totally dead still. they didn't clean cable ends all that was wrong
MrMarty51
Eastern Montana
Martin
Well, I guess, problem solved.
One nice thing is, You now know what a fusible link is. :hahano:
Chevyboy12
Brandon
I changed it because on my battery when I bought the truck it was a 4 year old battery , and I just rebuilt my tranny so while I was up under there I went ahead and replaced my starter
Chevyboy12
Brandon
I just tested with a meter , the battery , alternator and starter they are all getting power what else could it be
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Did you check the junction on the firewall? If you have no power there, you have bad fusible links from the starter/alternator to the firewall junction.
Chevyboy12
Brandon
How do I check that and what is that ?
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
It's to the left of the brake booster, should have a bunch of wires going to it, with two posts with nuts holding everything down. You can test it for voltage just like anything else, positive probe on the junction, negative probe to ground.
Chevyboy12
Brandon
Okay ya I did the one to the right it has power
Chevyboy12
Brandon
Now my truck will only turn over when battery is hooked up to a power source engine acts as getting no spark
Johns C10 Hubcap
