As I mentioned, if you didn't own this straight from the factory, there is no telling what the previous owners did.
For example, on my 78:
(1) The previous owner wired the choke straight to the battery, which kept the choke open, AND drained the battery every couple days.
(2) I pulled about 20' of various wires out that taped into everything under the sun. It was obvious a stereo was pulled, cheap, crap gauges installed, wires cut to the heater motor and backups, . . . .
There is no telling what a previous, electronically challenged owner might have done. Many a fused wire is missing on these rigs [and were replaced with unprotected straight wires to the battery]
As to a new harness, these systems are really VERY simple, making them easy to correct. If you're going all in on one of these rigs, learning the details of working with the electrical is a must, just as much as is learning the ins-and-outs of swapping an engine, transmission or what have you.
Add to those corrections a few rules. Ones like shielding the harnesses from abrasion, be it with tape (the tapes used are NOT sticky, they are simple wraps secured at the ends or various places along their runs. Of course, you can buy the flex tubing too.
In the end, those temporary jumper wires are ONE OF your best friends. You can, temporarily, feed the block with 12, though I'd do it through a breaker, just in case.
