evlblkrfl
- Feb 8, 2024
- Southern Kalifornistan
- Chris
- K20
This is how im getting numbers. Hopefully its correct
The two wires on the right should go to the bulkhead (fuse box)you’re missing the feed wires to the junction block
Would it matter if the starter wire went on the left or right of the junction block? That's how its always been but if its not correct I'll definitely change it. That's just not of the things that was disturbed on this particular project
That was my next question…My fault I thought this was a no start, not a no crank. I saw intake replaced and skimmed the test lol
Well it is very obviously something that you did or touched. Because that junction is the main power feed distribution for the truck.
What's with the electrical tape on the left side of the block?
I admit I was wrong on my statement earlier, I found an old picture of my firewall and it looked almost the same just without the extra cut wire on the left.That's a cut wire from previous owner on the left junction block. It had an old time aftermarket A/C unit at one point and i believe that's what it went to. I'll be removing that
No. Don't do that.I appreciate all the replies, guys. This is a strange one. All my grounds (battery/engine/frame) are all clean and tight.Not sure where I'm gonna go from here. Damn it.....I guess I'll look at a new engine harness
