Electric cooling
jasm158
Dallas
Jason
I was wondering if any one could suggest a easy inexpensive electric fan that can keep my mild 350 with a/c?? Has clutch fan now...
Got a couple guys dealing with that right now on the forum. One has mentioned he is using fans from a Buick Rendevous I believe it was. Hopefully they'll be in here soon to be more specific.
heavyleft
Fayetteville, NC
V10/K5
350ci
I used a fan assembly from a Ford Windstar. Picked on up from junkyard for $40. Just another option. Shroud coverage over your radiator is key.
The Windstar fans work well on my '77, and so far the Rendezvous fans work great on my '84. I drive the '84 daily and just today I got stuck in a pretty long traffic jam in 90* weather, the fans had no trouble keeping the motor at 170 to 180 degrees at all times. However, my truck's AC is currently inop but I don't think that would cause it to run much hotter.
jasm158
Dallas
Jason
a friend of mine said to continue to use the clutch OE fan,and put electric in front of radiator to pull air in? can you use two fans like that?
That's fine if you just want a little extra cooling. The factory actually used that setup too, on some 3/4 tons and 1 tons. To me, the real benefit of electric fans is the minor improvement in fuel mileage and less drag on the motor. I'll be honest too, the biggest reason I converted my C10 is because my fan clutch locked up. A new fan clutch is 40 bucks or so, but I already had the fans, wiring, relay and switch. So the upgrade only cost me my time.
Hutch998
Wisconsin
Jake
Would the cooling fans from the buick or windstar be able to cool a 454? or would I need a better aftermarket version?
I'd be going out on a limb to say yes since I've not done it, but I'd say, provided you have the right size radiator, the fans will move enough air to cool that radiator.
sszcam
