Electric Choke Issue
Scott91370
Burleson, Tx
Scott
Sierra1500
Kind of working on getting the truck running and came across an odd issue. I have a 12v switch line going to the + side of the electric choke on an Edelbrock carb. Unhooked the wire shows 13.x volts. When I hook it up the voltage drops to 4ish + or -.
Any thoughts what could cause this to happen? I've never seen voltage drop like that.
Thanks!
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
Thanks!
you have a bad connection or switch. Use you voltmeter checking voltage and work your way back to the power source. could be bad crimp,bad wire, or bad switch
Red Rex
Middle Ga
K 1500 4 WD shortbed
I had to run a ground from the choke housing to the battery. Helped the choke and the electric solenoid for the ac
Scott91370
Burleson, Tx
Scott
Sierra1500
C10Mix Master - When I get the truck back together I will look into this. It's all factory wiring but on a 40 year old truck anything is possible.
Red Rex - That kind of sucks. But I suppose I could connect it to the heavy ground wire by the alternator if needed, or at least follow the same route.
Thanks guys!!
TubeTruck
East TN
Denis
Suburban K10
LQ9
Sounds like you got a short in the choke and it's grounding out when you connect it.
Jeremy89
