EGR Valve and dual exhaust
mcarlo86
ND
Suburban
The service engine soon light on our 1990 Suburban has been coming on lately so I checked the code and it comes up code 32. I believe that is related to the EGR valve. The previous owner removed the cat, but left the rest of the exhaust stock. The exhaust is shot, so I am planning to have dual exhaust installed. I have heard that EGR valves need proper back pressure to work correctly. Is this true? I have also heard that if I want to put dual exhaust on with no cat, that I should get a 'heated O2 sensor'. I had a 1989 K1500 back in the day that had dual exhaust and no cats and I don't remember having any EGR problems with that. If anyone has any experience with this stuff, please reply. Thanks.
350 w/203
You'll have to check the specific codes for your truck but in some vehicles a Code 32 is a vacuum leak.
Nonstop
Ca
Nick
K2500
It should not be too much of a problem with the egr - a lot of trucks came with dual exhaust, no cats, and egr from the factory.
mcarlo86
ND
Suburban
Once I read that it could be a vacuum leak, it came to mind that the air only blows out the dash vents and wouldn’t switch to the floor or defrost. I did some checking under the hood and found a vacuum hose that was disconnected from a ‘T’ above the distributor. I hooked that back up and now the heat and defrost work again and I haven’t had the service engine soon light come on since. Had dual exhaust put on and everything seems to be working just fine. Sounds a lot better than the old exhaust with holes in the muffler and leaks in the pipe where the previous owner attempted to weld a pipe in place of the cat. Thanks for the tip!
350 w/203
Good to hear you got it all straightened out! Sweet rumble!
mcarlo86
ND
Suburban
Shortly after I posted the reply above that I had everything figured out, the service engine soon light came on again. Changed out the EGR valve and replaced a bunch of rotted out vacuum lines and I still get the light. Any other ideas? Could the EGR solenoid be a possible culprit?
Craig 85
Nashville, TN
454/TH-400/NP205
I know your truck has fuel injection and mine is carbed, but I ran into an issue when I had the engine replaced in my truck. The EGR ports/runners in the base of the intake manifold were totally loaded full of carbon crap. Even if I replaced the EGR, there was no way for the gases to recirculate due to the blockage.
Hopefully that's not the case for you, but I thought I'd throw it out there. I would think your truck would run way better the mine due to FI.
I believe code 32 on your truck is going to be a circuit malfunction not vacuum,not valve itself, not clogged anything. Double check me but if that is a circuit malfunction code it's going to be wiring, com, or solenoid
mcarlo86
ND
Suburban
Looking into code 32 a bit further, I found this:
http://www.fieros.de/en/v6help/code...ext=EGR duty cycle commanded by,, (7" vacuum).
Problem Description:
Code 32 means that the EGR diagnostic switch was not detected closed under the following conditions:
  • Coolant temperature greater than 80 C (176 F).
  • EGR duty cycle commanded by the ECM is greater than 50%.
  • Manifold pressure less than 25 kPa, (7" vacuum).
  • All conditions above must be met for about 8 seconds.
http://www.fieros.de/en/v6help/code32.html#:~:text=Code 32 means that the,closed under the following conditions:&text=EGR duty cycle commanded by,, (7" vacuum).
So you need to look and see why the switch isn't detected closed. Broken wire?unplugged?Worn out switch?is the switch getting the signal to close.
mcarlo86
ND
Suburban
Did a little more investigating tonight. I squeezed the egr valve with the engine idling and it stumbled, so I believe the passages are open in the intake. I pulled the wiring plug off the egr solenoid and I have 12v at the plug. I then used the multi-meter to check the ohms on the solenoid and had around 300, so I think that should be ok? I read somewhere that there is supposed to be a vent on the solenoid that can plug up with dirt, but I have no idea where that would be at on it. I cleared the codes and took it for a drive. After about 15 miles, the check engine light came on. Checked the code and it is still 32. Any other suggestions?
Malo83
