EGR Plug?
Doppleganger
OH-MI: Just like it sounds
My truck (85 K20) was from the left coast and had Cali emissions on it with the air pipes into the paper towel rolls that double as an exhaust manifold. I got everything off today but have the large threaded holes to fill. I think they are 7/8" (thats about what they mic at) but have seen both 14 and 15 thread pitches available.
Anyone already do this and know a PN or at least a size? I can find what it is with my pipe but would rather get it found or ordered ASAP.
Thanks much.
Snoots
Roger
Jimmy Sierra
350 w/203
Can you weld?
legopnuematic
Licensed Junk Dealer
MO
Spencer
My bet would be 1/2-14 NPT threads, however if you got a welder just cut the tubes from the fittings and weld the holes up.
Doppleganger
I suppose the direct way is to weld the original end shut. I took the pipe to Parker Triad - he said the thread is M22 x 1.25. They have no direct fitting plugs and the one thats close was $14. Forget that.
I had two 1/2" brass plugs - no idea why - and some 2400 degree muffler cement. Plug went in - isn't coming out.
These manifolds will be on a boat to China next year to make new Fords anyways.....so meh.
JIMYB
