edelbrock carburetor solutions
Squirrely Brother
Dallas, TX
Alan
@AuroraGirl I looked at the Edelbrock pump, but it was so tiny compared to the Holley I had on my 1972, so much so that I was skeptical of long term performance. That’s just me though. I found Carter pumps specify an actual psi flow compared to other vendors where there was a range or not even shown. The pump from O’Reillys fluctuated between 11-12 psi, which the Edelbrock sure didn’t like.
I hope you gets yours road worthy soon with minimal frustration along the way.
Squirrely Brother
Dallas, TX
Alan
@AuroraGirl I misread. You said a fuel filter with a return provision. Not a filter on the return line. I did the Summit banjo line with built in filter. Worked well, clean install and no heat issues.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Pitch it in the trash, solved lol
Are we also gonna A new power plant for it too? Maybe.. there’s a member who roams these forms preaching of them.. I can’t quite remember the engine family...something To Do with Lesbian Sex?
im sure he will find us
LOL
NO ITS GONNA BE frustrating. Although, since I’m gonna have to be fristrated,I’m getting a thread chaser kit and a lot of thread compound because I want to not hate myself next time I have to touch anything
Chrysler did these filters because.. I’m not sure.
Here’s a fun explanation
SirRobyn0
Rob
@AuroraGirl & @Squirrely Brother Those fuel filters you are talking are really great. On a square that is single line I'd simply install a return type fuel pump and plumb it in. But one of the best things about the return fuel filter is that you can mount it right up close to the carb. I've done that on old class c motorhomes with vapor lock issues.
For some of us we have found that 6PSI is to much for our carbs on a hot day. For that reason I like to run a regulator. I'm just running a normal run of the mill regulator, but their are units that incorporate a return line.
oh. edelbrock website made it seem that was on-the-spot for their 1406. i figured 6 psi with maybe the rubber line was enough give to maybe lower enough. or a fuel filter with a return vapor could be enough to bleed off pressures.
SirRobyn0
Rob
It is what it is. I'm not 100% sure why they sell the pump they do and I know some folks have had great luck with them. I've also seen Edelbrocks reject anything over 5psi. And some folks not running a regulator or special pump running god only knows how many psi of fuel pressure and they are happy. I have just found that a regulator something that can be adjusted to what the carb likes has been the way to go for me, and at the shop at least.
It’s really why I’m gonna hold off replacing the fuel pump as long as it works and no leaks in every way except fuel drain back which a 5 $
Dollar check valve in line before my wix filter fixed
if I have to replace fuel pump period, qjet is going on
Adis
