- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
You can buy the head pre-lumped from MrHotRod6. You don't have to enlarge the valves right away, you can leave it with stock valves and still see some gains. If later on you decided to have bigger valves put in, you could install your stock head and run it while the work was being done.
I am with you on there being so many paths to take. That is why it has taken me so long to acquire all my parts for the direction I chose on my 292. I now have 99% of the parts, but will have an engine that will run way better than stock. I still need to get the rod bearings and main bearings, and check the bores. I may still need pistons, or I may be able to leave the stock ones in there. But I tossed around the Clifford/Weber setup. The Offenhauser. The Aussie Speed. Quadrajet. Holley. 2G. Quadrajet. Holley. 2G. Holley 2G Sniper EFI. Quadrajet. I waffled all over the place. Then which cam to go with the improved air flow but maintain good low end while improving the cruise mid-range and a cam that plays nice with the valve train. Then I'd go to buy the parts and 12Bolt would be sold out. This year when I saw they were available I jumped on them quickly and soon saw what I ordered had sold out. Didn't matter, I got mine for my project. I was actually set on buying the Offenhauser, there is a local shop an hour away that sells them. I missed calling them by one minute before they closed. That same night I was browsing ebay and saw the Aussie Speed. It was cheaper than the Offy, and what I actually wanted all along, I just didn't want to spend the money on shipping to the states, and the aussie intake I found was from mrhotrod6 out of Florida. One thing I like about the aussie is it doesn't require an adapter plate to run a Holley. So to run a Q-Jet I just need a squarebore-to-spreadbore adapter if I later choose to run a Q-Jet. And, with the 2G adapter I had made for the aussie, if I decide to spend the money on a 2G sniper efi, I have the adapter for it. I bought parts that allowed me to have options down the road without having to buy a new intake. Only thing I can recommend is pick the path and stick with it. You can always buy more parts to improve upon what you already bought and only take a day or weekend for the upgrade.
