Driver4r's Monte
Driver4r
Nebraska
Trevor
k10,c20
Its in the car and its in the final stages.
Driver4r
Nebraska
Trevor
k10,c20
Did some more work to the monte today even tho the weather was ****.
I made a new metal line goign to the vacume modulator.
And i picked up this toy for the monte.
Moderator Administrator
Those SunPros are fairly good for the money. And I always like full sweep gauges for Oil and Water. Volts isn't as critical so it's all good.
Driver4r
Nebraska
Trevor
k10,c20
I agree, sunpro's been around for YEARS. They had this set and 3 other styles, it came down to this one and the other black with black faces, this one stood out more cause of the full sweep. I wanted a more precise oil guage and temp guage.
Honestly, I didnt need any of them, my guage cluster has all 3, but I preferr mechanical guages over electric anyday.(excluding tach, i have to run electric there lol)
I've always had aftermarket mechanicals with my own pilot idiots lights on my hipo vehicles. Didn't want to trust the OEM wiring. Usually used the Deluxe Series Stewart Warner gauges. They're now considered Vintage.
Driver4r
Nebraska
Trevor
k10,c20
And a tip to ANYONE that runs a aftermarket oil guage.
Upgrade.... Its not the cheepest, but its alot better than plastic.
Driver4r
Nebraska
Trevor
k10,c20
Since i had to wait for this to finish my oil plumbing, tomarro i should be priming the system.
Driver4r
Nebraska
Trevor
k10,c20
Today i got a lot of small things done.
Put a tstat neck on and sealed it all up.
Ran the oil pressure line.
Hooked up the temp sensor line.
Layed the wiring over the engine.
Reworked my trans vac line a little.
Modified and installed my throttle bracket.
Ordered My header gaskets, those fuckers were 50$.
hooked up my heater lines.
Temporarily mounted my guages( i need a 90 degree drill adapter).
Driver4r
Nebraska
Trevor
k10,c20
Today:
Put the starter in.
Got the converter bolts, 2 of the 3 are in.
Put on some brackets.
Header gaskets should be here tomarro.
Driver4r
Nebraska
Trevor
k10,c20
Tomarro should be the day ive been waiting for :D :D
These finally got here and i got them installed.
Need to do's:
Trans fluid
trans lines
distributor
antifreze/water
fuel line
Vacume line
tighten engine mount bolts.
Driver4r
Nebraska
Trevor
k10,c20
It happened :banana-mario::banana-mario::banana-mario::banana-mario::banana-mario::banana-mario::banana-mario::banana-mario::banana-mario::banana-mario::banana-mario:
Heres 2 pictures that i took befor it happened.
Who wants to hear it?
Driver4r
Nebraska
Trevor
k10,c20
You've got some tuning to do. And I do believe it's running rich. Get it dialed in, and it's going to sound better than that.
BTW, I'm assuming that's after the cam is already broke in? This isn't initial start up right?
Driver4r
Nebraska
Trevor
k10,c20
yea, the carb was trying to flood out, the needle kept wanting to stick.
This q-jet just has to run good enough untill i can get my holley put together.
Between the exhaust and the timing set, it was hard to hear the rockers, so we need to get a set of slip on mufflers to be able to set lash better. Its close but not 100% perfect.
I was wanting to dump it in front of the tires, but i think i might settle with dumping it befor the axle.
650 DP Mech secondary. And im gonna convert it to mechanical choke.
nixon22
