Scott91370
- Apr 2, 2018
- Burleson, Tx
- Scott
- Sierra1500
Anybody have any tips on this? I downloaded the install manual and watched a video 9mine are power the video was manual but the same should apply) and still can't get my windows installed.
Here are the instructions from the service manual:
REMOVE WINDOW
1. Remove ventilator assembly as previously outlined.
2. Slide glass forward until front roller is in line with
notch in sash channel. Disengage roller from channel.
3. Push window forward and tilt front portion of window
up until rear roller is disengaged.
4. Put window assembly in normal position (level) and
raise straight up and out.
5. Reverse above procedure for installation.
I wrote these out so I didn't have to think about it while I was doing it-
INSTALL WINDOW
1. Put window assembly in normal position (level) and lower straight down and in.
2. Push window forward and tilt front portion of window up until rear roller is engaged.
3. Slide glass forward until front roller is in line with notch in sash channel. Engage roller into channel.
4. Install ventilator assembly.
Here's the video. If I get my window regulator that high it gets stuck:
REMOVE WINDOW
INSTALL WINDOW
