Door panel rehab
Brunc
irving Texas
Michael
Not sure what I am actually asking, but here it goes. I took the interior door panels off and cleaned them. The plastic is soft, I can take my thumbnail and scrape off a layer.
Is there away to stabilize the surface so I can paint them. I figured I would just sand down to good plastic and the prime and paint, unless there is another route that would end up with good results
84GMCSierra
Supporting Member Air Force
Central Arizona
C2500
I think I sanded mine with fine grit paper then just painted them with Krylon Matte Blue spray paint. They came out pretty good for a driver. Color is fairly close to the original blue in my 84 Sierra. When I bought my truck in 2019, it had sat in the Phoenix sun for 5 years, so they needed a little attention. I'll post pics later today.
Sad Sack
Nebraska
Goober
C15
Wonder how it would turn out if one would sand down to good plastic and brush coat with fiberglass resin, sand and paint?
The Right side of Washington
Sounds like a fck load of work for likely not great results. I’d be concerned about the resin eating up that old soft plastic too.
Just solvent prep them with something not too hot and spray em with any number of available “dyes.”
The crispy parts will absorb a lot. But it will harden up the surface a make it more scratch resistant.
Sad Sack
Nebraska
Goober
C15
Agreed, but fiberglass can be used on plastic....
They are honestly cheap enough get some new ones from LMC or CJ pony parts
I’m cheap though! lol.
Have to disassemble everything anyways so not much more time. But $30 for a couple cans of SEM vs $100s depending on model is a lot of beer money!
Now daily driver, extreme uv exposure, heavy wear n tear, I’d probably spring for some new plastic.
But I like the “almost free” results.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Most important part of this quote : is a lot of beer money!
:dogpile:
Scruffy49
Law Enforcement Navy
Rosemark TN
Jeff
C10 swb
4.3L
Daily driver grade? Get a couple cans of Rustoleum bedliner spray, adhesion promoter, and Krylon Fusion color of choice.
1. Scrub the panels with Dawn and a fingernail brush. Repeat until the rinse off is clear.
2. Spray adhesion promoter, follow the working window directions.
3. Spray with bedliner. Follow recoat times to the letter. Let it cure at least 1 full week.
4. Spray with Fusion, follow recoat times.
You now have solid, fully textured custom door plastics, for maybe $100.
I build 60s Dodges, new door plastics are not available. If the panels are cracked, back them with fiberglass cloth and a quality resin like a West Marine product.
84GMCSierra
Central Arizona
C2500
Here's my door panel with the Krylon
jw23655
