- Oct 30, 2019
- Downingtown, PA
- Wayne
- Jimmy
I agree with you it’s a 350 I believe someone swapped the fan at some point every v8 I’ve ever owned had a 5 blade fan. And it is a CK 20 4sp sm465 and 205 transfer case. I’ll remove the pulley and see.
My 1974 Jimmy 350, also with the SM465 came from the factory with an aluminum flex fan. At around 5 or 6 years old one blade broke off. It busted a piece of the shroud and cut the brake line where it crosses the frame when it flew out.
At that time, no dealers had the fan and they were back ordered. I ended up putting an aftermarket fiberglass flex fan on. I would bet that is why your '73 has that 6 cylinder fan on it.
