Dome Light and Courtesy light HELP NEEDED
Mr. Square
Wisconsin
Austin
On my 83' Silverado im having an issue with my interior lights. My dome and courtesy light both wont work. Both fuses are fine and both bulbs are good also, but my problem lies between the dome and horn circuit. When i plug in a bulb into the dome the fuse blows, and when i dont have a bulb installed the horn works and the fuse is fine. has anyone had this problem before?
Georgeb
Wisconsin
George
K10 Burb Z71
Which fuse blows?
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
You have a grounded short somewhere in the circuit. Check the wiring at the door pin that activates the dome light, also check the wire connections at the dome light housing as well. Both of these connections were issues on my 84. Sometimes the electrical connections inside the dome light housings ground out due to a melted contact. I switched over to leds for all of the interioir light to eleiminate the issue. Incandescent bulbs get very hot when in use and can cause issues.
Mr. Square
Wisconsin
Austin
Ok will do thats what i was thinking could be the problem.
wingman50
Chicago
5.7L
I had the same problem. Put in a new in the dome light socket which blew the fuse. It took a long time to figure it out that it was the bulb. I was putting a single contact bulb in the dome light socket that has a DOUBLE Contact. The single contact bulb will short the fuse. Try the double contact bulb. That worked for me.
Georgeb
Wisconsin
George
K10 Burb Z71
This makes sense. It would be a direct short to ground with either door open or the dome light swiched on at the headlight switch. The white wire is a switched ground and the orange is hot at all times.
Mr. Square
Wisconsin
Austin
I first tried the double contact bulb when i first attempted to get the dome to work. i think its got to be the door switches. there isnt any bare wires on the floor that leads to the dome light itself.
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
check the wires under the door sill cover . mine where melted together from being pinched i replaced 2 feet of wire fixed it ... just saying
87scotty
Central il
Andrew
V20
5.7 for now
I replaced from just under dash all the way up! Just hook your old wire up to new one and pull er through.
Lonestar33
