Does my 1990 Suburban 1500 4x4 have open or locking Rear Differential?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Look inside the glove box, at the SPID, tell me if you see a code that says "G80"
If you do, congrats, you're an owner of the corporate low speed posi traction.
(I'll leave out all the hate about them so as to not ruin the fun)
motohunter4
US
Hunter
Can't see a picture?
Sent from my SM-A205U using Tapatalk
Vbb199
Salisbury NC
Vince
Right here.
Don't be so sure it's the Gov Lok. @89Suburban had a Burb with a G80 and his had a Limited Slip what appeared to be an Eaton unit. Maybe it was replaced at one time? :shrug: But it seems someone else had G80 SPID label in a later model Burb and it too was a Limited Slip. Only way to know for certain is to remove the rear cover and ID it.
motohunter4
US
Hunter
Are the $300 Yukon ones worth a damn?
Vbb199
Salisbury NC
Vince
You got a point there.
Was just thinking about that, someone might've replaced Giant Rock's rear end at some point.
In that white parts burb I had, the rear end was limited slip as well.
But it was obviously redone at some point, the gears were too nice, and the unit itself looked too clean.
Vbb199
Salisbury NC
Vince
I haven't heard many bad stories about Yukon components, all really depends on how you're treating the axle and it's locking mechanism.
motohunter4
US
Hunter
I'm too old and cheap to abuse it.
Giant Rock
Joshua Tree, CA
Cole
Suburban v1500
5.7 V8
Ok will do! Just dropped her off at the tire shop for some new shoes, soon as I pick it up later today I will report back. Thanks!
motohunter4
US
Hunter
Right here.
I wish my shitbox still had that sticker.
Keith Seymore
Motor City
Keith Seymore
4.3L
motohunter4
US
Hunter
Just disassembling it I know I have a 5.7, NP208, 700r4 and open diffs. I would like to know the option package, but not for $50. Weird, BMW will do it for free. 1983 it's out the window anyway. I'm adding options as I go. Mostly subtracting them.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Open diff. Not the end of the world, but your dreams of an epic mud bogging rig are over.
Seriously though, mine came the same way with open diffs. I needed more traction once in a while so I opted for a lunch box locker up front. Problem solved.
Bean_64
