Do I need a block heater?
Washington
40 below and uphill to school ....both ways!
And Cummins doesn’t have glow plugs.
Washington
Iiiiiits 40 below, don’t give a ****.
Gotta heater in my truck, and I’m off to the rodeo!
Shorty81
Baby Boomer
North West ohio
Darren
It's allemande left allemande right come on you f#####g dummy get your right step right...
Turbo4whl
Downingtown, PA
Wayne
Is that the recirculating type? Or where does it go?
Yes, recirulating. To install, remove the block drain, (1/4" pipe thread) on the passenger side of the engine. 5/8" heater hose from the new fitting installed in the block drain to the lower fitting of the block heater (90 degree).
Cut the heater hose that goes to the top of the intake manifold. Install the "T". Top fitting on the block heater to that "T". Best to have the block heater inlet lower than engine block drain that feeds it.
The block heater has a check valve at the inlet so it will not effect normal heater hose flow.
I
I should get that kind for my square eventually, being its a plow truck. cut down on warm up time for sure.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
You’re correct. Cummins use a grid heater instead of glow plugs. I don’t know if your reply was directed at me, I’m too lazy to go back and look at my comments. If I said glow plugs I’ll revise my statement.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Kidding, obviously some of you fine gentlemen can't really help that.
If you had 2 block heaters and Tommy had 1 block heater and you sold 5 block heaters. CTFO haven't we told him all he needs to know about block heaters?
Don't make me derail this with another cat post.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
From the "Great White North"
First time you crank the engine in -25c, which is a lot of the time up here in winter you will know the answer.
Spending hours and $$$ in mornings, freezing your butt trying to get some place, Sucks!
Where in Canada is Parksville?
Vbb199
Salisbury NC
Vince
Yet ANOTHER thread that goes on for dayyyyysssssssss about a specific topic.
Damn everyone must be bored.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
They make high quality block heaters that replace frost plugs. It's a machined brass plug with an O ring. Stay away from the pressed steel type plugs.
When I lived and worked in the oil field in Saskatchewan I had to face minus 30C all the time. I had two frost plug type heaters plus and inline to the heater hose and an internal AC heater. I needed a 30amp plug to handle it all. Wired in a 110/220 timer to turn it on at 3am.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
This thread made think of this song lmfao
joshuars
