diy4x guardsmen 14 bolt
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
This thing is huge shouldbe able to sit the whole truck on it. Going to have it powder coated. Then puter on
77 K20
Montana
K20 5" lift
HT383 fuel injected
*tracking* I've looked at that as I thought it would offer great protection.
Powder coating would be a good idea. I was thinking it might get packed full of mud and snow a lot and then require me to clean it out a lot. Not sure that would be an issue or not.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Heres some pictures of it
77 K20
Montana
K20 5" lift
HT383 fuel injected
So how was the install? Did it come with those bolts? Looking good!
Now that it is on, what do you think?
marks86
Latham, NY
Mark
12v Cummins
I need one of those. nice product
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Install only took maybe 20mins. Unbolted drive shaft dang cup came off had to put some bearings back in line then taped it up so it wouldn't happen again then the 6 or so bolts around the pinion came out and it slid right over the yoke into place then the grade 8 bolts that came with it went back in...theyre alittle longer then the other ones to make up the thickness of the guard. It was really easy.
Ill let you know next time i go muddin if it scoops up mud. It may act like a slide and go over it ...it is higher then the bottom of the dif to so itll hit dif first or its going to dig in like a shovel. Ill let ya know
firebane
Calgary, AB
Curtis
In any deep water or mud I've heard of these things acting like a shovel and scooping up water/mud/dirt and even people getting stuck because they get stuck against something.
Looks good though.
co703op
