Did my truck come this way??
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
what year did headliners and pillar molding become standard equipment?
It didn't.
No dome light?
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
It didn't.
No dome light?
nope, the ceiling just has the three vinyl plugs that i'm assuming you'd attach a headliner to. i think the previous owner resprayed the inside of the truck when they did the cab swap…i figured it just looked too new to be original.
would the dome light mount in the headliner itself? there's nowhere for any wires to get there that i can find...
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
makes me wonder what year my cab is…
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
this one's a little further out, you can see the three black "plugs" i'm referring to
yevgenievich
Place
Name
Year
Model
Size
There is space behind to run wires for dome light
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
weird, the carpet kit on mine stops 6 or 8 inches below the back window. the way it terminates fits the body line back there. must not be factory either.
they came with carpet all the way up the back behind the seats? mine is the same painted metal above where the carpet ends.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Headliner I believe only came in Silverado or Grand Sierra trim...?
The black plugs are only there to fill the holes somebody drilled for some reason. Likely to push out dents in the roof skin. That grab handle was also added. Later Suburbans got those.
CSFJ
dome lights, would have a stamped opening in the rear of the steel roof panel.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
i always assumed it was for a headliner… now i'm really wondering. don't think they were for body work. they're only in the inner skin and the actual exterior top of the truck has no signs of body work; looks new.
should it be visible here?
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
^^^frosty in there this morning
Yes, those plugs would only be on the inner skin to gain access for pushing on the outer skin. When bodywork is done well, you won't be able to see where it was done. That's kinda the point in fixing dents, lol.
Also note, they are not evenly spaced on the roof.
Danstanley99
