Did I Damage 94--5.7 engine???
Durfman77
Michigan
Charles
GMC
Well I put new radiator and new engine oil lines in and been ok for couple days BUT on a 60 mile trip I just pulled into a small town with one stop sign and just started to pull away and looked down to see hardly any [oil pressure]?
I shut off engine and costed to a parking lot where I seen ALOT oil dripping?------I took off oil line and the o-ring broke in-two-----I only went maybe 1/8 of mile from stop sign so walked back to see drops of oil all the way and a puddle at stop sign and drops going down road from stop sign,
So got and put gal of oil back in with another o-ring and engine seems to be running ok??
SO if it was still spitting oil out even hardly no pressure on gauge do you think I damage engine??
Moderator
If it was still leaking, then the pump still had at least a little bit of oil to keep circulating. It's probably fine.
If it's not knocking and has the same oil pressure you're good. The tell is if the oil pressure is lower.The rod bearings are last oiled, so first starved.If you wipe bearing material from no oil,then bearing clearance is increased and oil pressure drops,and or you get rod knock.
Durfman77
Michigan
Charles
GMC
If it's not knocking and has the same oil pressure you're good. The tell is if the oil pressure is lower.The rod bearings are last oiled, so first starved.If you wipe bearing material from no oil clearance is increased and oil pressure drops,and or you get rod knock.
Well I have no knocking and oil pressure I cant say cause I run 5w-40 full synthetic schaffers in it and now all I could get was regulars 5w-30 so oil pressure is a tad lower now but I should change oil to what I use and cut open filter?
Moderator
Imho, if you had Shaffers in it before, then your chances of it not being hurt are even greater. That stuff really clings from what I've seen.
Durfman77
Michigan
Charles
GMC
I dont understand why Shaffers would be bad for engine??
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
No problem ....Sunday morning=less brain engagement
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
@78C10BigTen Yeah Ted, I don't have to worry bout that anymore!!!!.....also Kooper's s10 is painted, gotta get it back together now, will have pics SOON!!!!
Shorty81
Baby Boomer
North West ohio
Darren
I use Shaeffer Supreme 7000 full synthetic 10W30. Good stuff.
sunking
